Many times the new guys asks questions about shop safety so here are some things to keep in mind.
1. wear safety glasses
2. No rings, jewerly or long sleeves around rotating equipment
3. Learn to turn the machine off before you learn how to start it.
4.Keep the work area uncluttered.
5.Wear safety equipment if you are handling acid (keep baking soda handy).
6.Keep a bucket of clean sand handy (not dirt)many metals and alloy have the ability
for self sustaining ignition (class D fires)
water will not extingush them, will only make steam or cause an explosion, do attempt to put out oil fire with fire you'll just spread the fire.
7.Be careful with steam, if you have steam explosion get on the deck, steam rises and if your standing up your lungs will fill with water and you'll drown. Also don't build boilers or other steam vessel out of old containers or water heaters like some morons advicate, they'll blow up.
A blind machinist with no fingers is pretty useless. Please be safe for every one combat casualty I saw in the service I saw five accident casualties. Above all before you attempt something questionable ask someone with experience or log on here and ask for help. Jim
