I just had to share this with everyone. I have been playing around with a hand scraper and small (2" square) cast iron angle plate. After about 45 minutes worth of scraping and spotting, I have gotten it flat enough to just stick (wring) to a dry, flat surface. Add a little oil between the two and it takes some effort to pull apart. I was skeptical about my ability to do this but it really wasn't that hard. Granted, it's not the same as rescraping the ways of a machine tool, but it is a start! Next, I would like to take 3 blocks of cast iron and generate my own surface plates.
Let's see, all I would need to do then is make a straightedge, some templates, a spindle test bar, find a climate controlled room and I can rebuild my Logan...........
Oh well, one step at a time I guess.
Greg
Greg
