AXA dovetail size
  • AXA dovetail size
    I'm in the process of building myself a piston style AXA tool post and would like to make it compatible with the majority of the tool holders out there. So I would really appreciate it if someone would measure the dovetail size on their phase II or Aloris posts, dorian need not apply as they seem to be a slightly different size from what I've read.
    This dimension should be relatively easy to get with 2 pins and an outside mic and I'd appreciate it a ton.
    Measurement
    Aloris AXA 2 pin size .251 measurment between pins with adjustable parrallels and a mic. 1.012 good luck with the project.
    Ad maiorem dei gloriam - Ad vitam paramus
      These are the dimensions I use from a Phase II toolholder. (.250" dia. pins)
      Jan
