TurnPro Lathe
  • TurnPro Lathe
    Does anyone have experience with a Turn Pro lathe from Enco? I have been looking at the 13 x 40 for a couple of years now.
    I have had a Jet 12 x 36 for about 20 years and have had no problems, but I would like to upgrade a little to the D4 spindle, gearhead, and a larger taper in the tailstock -Also want a DRO, I think; are they reliable? My digital calipers I bought about the time I bought the Jet lathe did not last long, but my dial calipers are all doing fine
    Not familiar with that lathe, but the dial calipers will last longer than digital.
      twinstar,
      I own one of the Turn Pro 1340 lathes. It has been a very good lathe. It is 10 years old and has had no problems. I have a DRO, taper attachment, micrometer stop and a 5c lever collet closer for it. The lathe is very accurate and very repetable. The manufacture of the lathe is Lux Matter in Taiwan.
      http://www.combitech.com.tw/luxmatter/lux1340g.htm
      Mark Hockett
        Thank you!
        Thanks, Millman and Mark, for your comments. TurnPro it is!
        In general, are DROs on machine tools more reliable than the digital calipers? What would be a good brand to buy to add to my existing Jet lathe and Jet mill, should I want to do that sometime later, and are DROs worth the investment?
