Useful 4 x 6 bandsaw gadget
  • Useful 4 x 6 bandsaw gadget
    Problem: Cut a 0.25" slice from a piece of 1.5" bar that is only 1.25" long.
    (I really am that cheap but in most cases it's a matter of the only piece of
    right-size stock in the shop being a teensy leftover.)
    Solution:
    Get a 'suitably narrow'* old drill press vise, drill and tap it and mount it
    vertically to a small piece of plywood. Add a little stop block at the right
    spot.
    Drop this contraption into the 4 x 6 bandsaw vise using the stop block to
    position it properly.
    Drop the bandsaw cutting head and saw away.
    Actually, the pictures are set ups. I built this eons ago and have used it
    happily for years. While I consider it a simple 'form follows function'
    solution to a problem, enough people have commented on it that I thought it
    might be worth passing along. Besides, I had the camera out and, for once, the
    [email protected]#$% batteries were charged.
    This is an ideal use for those hopelessly out-of-square, porous casting
    Chinese junk vises one can buy for a pittance at the usual suspects.
    * suitably narrow means that the width of the DP vise is small enough to fit
    between the saw arm and the blade. If you make one, be sure to check this
    dimension first.
    Regards, Marv
    This appears a usefull device for holding short pieces for cutting.
      Another 4 x 6 saw gadget.
      You will never believe how much money I have made with this saw and bar feeder. The bar feeder was made with air cylinders and valves recovered from the junk where I work. It is controlled by an Allen-Bradely PLC.
      Jim
      So much to learn, so little time
        Just a question. In this particular case wouldn't have been easier and fast to just part the piece off in the lathe? Nice idea though.
          I like both of your gadgets. I will send you a self address stamped box for the trip to my garage.
          OUtback,
          Are you willing to take a couple detailed pics of your saw? I've had all of the parts to build one for quite a while, just haven't had the time.
            Perhaps in the case of the cylindrical stock I stuck in there for the photograph.
            However, this works well for cases where lathe parting won't - e.g., flat plate.
            Regards, Marv
              That's a good idea. The stock clamp is only ever partially useful and always seems to need modifying.
              Outback- How about a couple more pics of that feeder and clamps and some more info on how you're using it. I'm really intrigued by it.
              Kevin
                Kevin
                Ditto. Looks cool, but not 100% sure what you're doing with it.
                You never learn anything by doing it right.
