I need some help!!!
  • #16
    Originally posted by dgh43
    I hunt deer and squirrel mostly they stand still the longest . But I really enjoy punching holes in paper.
    Yes I enjoy paper punching as well. My boys took me out grouse hunting this fall. I shot the ones on the trail and they tramped through the bush.
    Here is a photo of a Spruce Grouse that I took with my HPA .177 .
    • #17
      Yep, 1/4"shaft and 0.2" pitch. I'll look tonight. I have boxes of these left over from when I worked on photocopiers. I may even have one with the correct keying.
      Around my place I just open the door on the truck as I drive up the driveway and grab them by the neck.
      • #18
        That would be great just let me know what you want for it.
        • #19
          I have a pulley that will work. I was able to modify one in my stash to do the job and it is all metal. Please PM (private message) me your address and I will send it to you. It will cost you a picture of it in use.
          (Just the stand with rifle will do, outside )
          It doesn't have the key but has a setscrew in the right place that will hold on the flat just fine.
          • #20
            Aaaaaaaaaaahhhhhhhhhhhaaaaaaaa
            I don't believe it, shades of the 21st century.
            Evan with a DIGITAL caliper,
            [ And it's showing the right time ]
            • #21
              I sent you a PM.
              • #22
                I found it on the road.
                • #23
                  DGH,
                  I am curious what prompted you to ask for help on this forum.
                  • #24
                    Lucky it didn't get scratched
                    • #25
                      I cant believe you got one of those just laying around Ev,, This may be a Wopticle dillusion (mainly because im the one looking at it) but what about gear teeth width? the plastic gear looks much taller to me as it sits no?
                      • #26
                        DGH,
                        Well I done a search for machinist forums cause I thought I was going to have to have one made. It didn't occur to me to just find one already made.
                        • #27
                          It's the same width as the belt. The plastic gear is slightly taller but part of the illusion is the angle I took the photo at. It will work. You wouldn't believe what I have laying around.... maybe you would...
                          DGH,
                          Well, you came to the right place. There are plenty of people here ready to help out. If it weren't myself George or somebody else would have fixed you up.
                          • #28
                            Originally posted by A.K. Boomer
                            I cant believe you got one of those just laying around[...]
                            -Actually, that's not even slightly hard to believe. I've seen literally dozens of that exact size belt (and cogs) in various printers and plotters.
                            The fact is, more and more companies are using more and more "off the shelf" parts, onbly using custom-made pieces when they absolutely need to. It's easier (source the parts from a manufacturer- that way you don't have to have the facilities to make them yourself) cheaper, and usually faster (they already have them on the shelf.)
                            The upshot of it is, that the same motor or stepper, belt and gear might be used in ten or twenty different products. And since they're making, using and then scrapping about a million or three photocopiers and printers every year, those of us that strip them down for fun and interesting parts tend to wind up with a basketful of them.
                            Doc.
                            • #29
                              Doc,
                              It's really hard to find that stuff made from metal these days. They are all some sort of plastic. I have a bunch that will do ok but are some sort of injection molded fibre filled polymer, probably acetal. The metal ones I have are from long ago when a photocopier weighed half a ton for an ordinary office model. All electromechanical with nary a semiconductor in sight and a huge aluminum frame with a 1hp drive motor.
