raised in diapers, levelled off in levi's, lowered in diapers. that's life.
c-2, c-5 carbide what’s the difference?
i would just like to here from someone to see if i did this right. i have 1942 reedprentice 16"lathe and 193210"regal leblond rong fu tablemill please reply to [email protected]freightbone
when using c-2 for aluminum make sure you have plenty of rake on front side or you get rubbing from the tool to the material. i have also bought cheap carbides to see what i could do. i have learned to respect the Quality of the tool, don't make to heavy of cuts intil you know what you can get away with. i will never machine cast iron again on my machines because the stuff cums off like sand and gets in the machine. LEARNED the hard way.freightbone
If we are on the subject of money and cutters then tell me why any hobby machinest would buy carbide lathe tools? I have yet to find anything the HHS tools won't do. I can grind then whatever shape the job requires and they last almost forever. I have tried brazed carbide tools and never got results as good as with HHS tools.
I do understand that in a production environment with simi-skilled workers that indexable tools would be invaluable. But we are talking about hobby shops here and not a production shops.
Am I missing something here?
Thanks
Joe
Joe, you are not missing anything. Most hobbiest type lathes do not have the rigidity to take advantage of carbide cutters to begin with. HSS is more versatile. Take a little time, and learn how to grind a cutter properly, and you will not be disappointed with results.
I think people are lured away from HSS by not having to grind cutters.
Set your bench grinder up with a medium and fine wheel, and dress the cutter with an India stone for fine edge.Jim H.
JCHannum:
I do not like the brazed carbide tools at all. I have seen some guys grind a postive lip into them to produce a half descent tool.
The best advance for people not wanting to grind their own HSS is http://www.arwarnerco.com/ and their T-15 HSS throw away insert type tools are worth a look. They are ideal for interupted cuts or stainless.
I prefer inserts, but I do have a lathe that is ridgid and powerful enough to do what I need them too (I know its limits). Even neutral rake tools in inserts are better engineered with superior materials, coatings, and tool holders.
I still grind form tools from HSS, T-15, or Carbide for special applications or for plastics.
