I need some tips on replacing the shafts and rebushing the 6-8" sheaves on some blocks from a 127 feet gaff rigged schooner. I have begun by replacing the bronze bushing in a bronze sheave and making a new shaft from 7/8ths oil hardening drill rod. Several questions, Best shaft clearance in bushing? Best grease? Best shaft material? Why not some kind of stainless with the bronze bushings? Would it be reasonable to bronze bush the cast iron sheaves that run in steel shafts. Oil impregnated bushings? Also any suggestions for best wood to replace the cheeks? Any obvious question I missed? These blocks are all torn down annually and regreased. By the way,the Captian says they have the most problems with the new ones they have bought. Best count is about 60 blocks. Sorry for so many questions?
Thanks Sav
Thanks Sav
