Darryl: I think your qquestion about DRO accuracy wnet unanswered; The DRO has two pieces, one mounts on the piecethat moves. the other mounts on the peice that dont move. The DRO tracks how much they move in relation to each other. You could mount a DRO and use a hammer or ccrow bar to movethings. Might have trouble positioning to where you want it, but you WILL know where its at
I think,for hobby purposes that most precision over say two /three inches is mainly for getting a warm fuzzy feeling. There is seldom need for great accuracy on big stuff. You may need a shaft 36" long and 1" dia. but in use it can probably be 36 plus minus a lot. and it needs to be 1" plus minus a little in two or three spots. The rest can be maybe smaller by a lot. Its niceto beable to make 6 holes equaly spaced, but in most cases there is no need for them to be exact- template and drill where the holes match. Gear is different matter, pulley can be way off except the anglle for belt needs to be fairly close. I tried to leave tolerance to max that would do the job for one off stuff.
For mass production thinngs change- parts must interchange- that needs precision especially when tolerance stack up.
The "Arkansas ruler" should be used when possible.
