Custom stainless tubing
  • Custom stainless tubing
    I am fixing to bore and sleeve some brake cylinders on my old forklift and needed some 1-1/16" OD stainless tubing to make the sleeves.Only problem was I couldn't find any.
    So what I did was buy some 1" OD x .043" wall seamless tubing and some 1" bearing balls.I cut a length of tubing off a little longer than the bore of the cylinder,swiped some grease in the end and used the arbor press and a deepwell socket to shove the ball through the tubing.
    It worked slick,nice shiney .999" bore and a 1.078" OD.Now I can bore the cylinders,stick the tube on a mandrel and turn the od to fit the bored hole.Ther'es more than one way to cheat at poker
    Their is a name for that .It is called ball sizing . So now you know.Been their done that.
      Actually it's called swaging,BTDT too
        Well whatever it's called it sounded like a "trick to remember" to me!
        SP
          Shoving your ball through a steel tube with a press- sounds, well----painful
            For that reason you always borrow someone elses balls for a project like that.
              Did it work harden, do you need to anneal it before machining?
              Ian
              All of the gear, no idea...
                Ian
                No and no,it's still soft gooey stainless.Looks like it will work great,sadly I won't be able to finish it untill next year.
