I am a bit confused could anyone explain to me the following.I understand that there are belt driven lathes I e the headstock has the availability to revolve at different speed according to the pulleys selected from the motor,countershaft, and spindle pulleys etc, that is not unclear.
Then there are geared head lathes which appear not to use belts . Or do they? and if they do what is their advantage.
Also the gearbox for selecting gears to alter the speeds for traversing the saddle and apron assembly and also including the screwcutting speeds etc that is also not difficult to realise what is going on.
However I have tried to read about the geared heads on lathes without much success, and it is very confusing (the little information I can find is very vague).
If you can alter the speeds on the headstock with gears why the need for a belt pulley system at all?
Or does a geared headstock do away with the need for a belt change system?
It appears from what I am reading that some lathes have both belt and geared heads and this does not make sense .I am beginning to wonder if this question makes any sense.
I hope someone can understand what I am on about and explain it or point me in the right direction with regard to where I can find out more .I have tried Google without success thanks Alistair
