can anyone please help. i need to drill/bore /ream. a 10.900 deep hole through 300 series stainless.blind hole .7875 dia. .3937 radius at the bottom. i would like a very high surface finish /straight bore hole.yes this is the start of a 1/6 scale napolean 12lbr. cannon. i have priced a custom reamer thru "clymer reamers" and they want $350.00 can. for this item. please don`t tell me to make my own reamer,i have neither the skill,heat treating equipment, nor the desire to try and build cutting tools that right now are far beyound my abilitys. right now ,the best way to do this job that i can figure out ,is to use a 19.5mm long series drill to full depth,then a 19.75mm ball nosed end mill with a welded extension, then a custom reamer. add up the tooling costs and this would be one expensive hole. i may not have any choice but to do it this way, but maybe the " GOD`S", "SAINTS" and or "wizord`s"of machine tool manipulation can explain a easier way to do this than my simpleton,vapour-locked brain can figure out! P.S. if anyone want's to build a very accurate napolean 12lbr. cannon try LARRY VAN SYOC in EMPORIA KANSAS, no affilliation but 100000% better than WILLAM F. GREEN'S PLANS not cheap, but well worth the $60.00 U.S i payed! nice to work with drawing's done by a machinist instead of an art school drop out/ draftsman/#@@%!&$)*/injin-eer!
"TOOL SLUT"
"TOOL SLUT"
