90 HP Honda outboard lift ring ?????
  • 90 HP Honda outboard lift ring ?????
    Anyone know the thread size/pitch on a 2006 Honda 90 HP outboard lift ring?
    It is a tool that threads into the top (flywheel) with a lift ring attached.
    Thanks for any info.
    Hellbender
    NRA Lifetime Member
    no idea , I assume that it would be metric.
    if i see my outboard mechanic i will ask , but i prolly wont be seeing him any time soon
      Everything on every Honda I've worked on, 2 or 4 wheels has been standard metric sizes, ie. 5x.08, 6x1, 8x1.25, 10,x1.5, 12x1.75.
      "Lay on ground-light fuse-get away"
        This thing is big, like 38 or 40 mm, and fine threaded.
        NRA Lifetime Member
          how annoying , need a special set up to screw into the flywheeland lift the engine .
          Yammys have a ring bolted on already to the block. Must have cost them 15 cents to do it.
            Fine Metric threads
            Digging around online. Couldn't find this in the Handbook:
            http://www.gewinde-normen.de/en/iso-fine-thread.html
            Never knew about these ISO fine metric sizes. Jim
            JimB
