Grizzly Collets
  • Grizzly Collets
    Included with the Grizzly G0516 combo, is a set of collets and a chuck. The chuck has a MT3 taper, which will work in both the headstock of the lathe and the mill. I'm now trying to find out if I can get additional collets for this chuch. It looks like some type of an ER style, but I cannot seem to match up the dimensions with any of the ER references on the web.
    Are any of you familiar with these collets/chucks? Is this a standard or a one-off Grizzly/Chinese thing?
    Here's what the set looks like:
    thanks,
    -Eric
    You might be able to match it up here:
    http://hardingeus.com/usr/pdf/collet/2348E.pdf
    But based on a quick scan, it's not listed.
      These collets are DIN 6388 specs form B.
      http://www.collets.de/en/p_a02b13.htm
