Royal 5C collets...accuracy??
  • HTRN
    Your experience is unusual. Nheng. We never got chewed up collets, and they were always problem free. But then, We ordered them direct from Lyndex.
    HTRN
  • nheng
    I have 3 Lyndex collets, purchased new from MSC for a job. The faces were heavily segmented (difficult to photograph), perhaps ground late on a Friday afternoon with a loaded wheel. The OD threads were a bit on the rough side also. The Hardinge, by comparison has a jewel-like appearance and accuracy to match. In my recollection, the Lyndex box said Japan. They also had sloppy radial slotting and heavy entry chamfers. Both collets shown are 3/32 although the Lyndex looks a bit larger due to the chamfer.
  • Alistair Hosie
    Happy new year from Scotland Krems regards. Alistair
  • Alistair Hosie
    If there is a dent in it can't you send it back for an exchange?Alistair
  • HTRN
    Lyndex was bought out by Nikken, and I can tell you that the Nikken Stuff is $$$$. I worked at one place that had a coupla Nikken integral shank Cat 40 boring heads, and They paid something like $700 each for them back in the early 90's. That same shop used Lyndex and Parlec Cat 40 toolholders(mostly Parlec's), and Lyndex collets - All DA's, mostly 180's.
    We never had a problem with the Lyndex collets, aside from occasionally having to replace a couple of them.
    HTRN
    If it was Japanese it would probably be good.....
    I bought one, a 3C, and I think it was from china....... it is ok for runout, but the threads are slightly different from a Hardinge.
  • DR
    Originally posted by HTRN
    Does Anybody besides Hardinge and Lyndex make a quality collet anymore?
    HTRN
    Lyndex doesn't make quality collets, at least not quality enough to be mentioned in the same breath with Hardinge.
    Next time you buy a Lyndex collet, check the box, it'll say made in Japan. Then check the collet, likely it won't even have the Lyndex name on it, much less the notation that it's made in Japan. Maybe only the box is made in Japan?
  • HTRN
    Royal guarantees all it's collets to be .0005 TIR or better. Note that not all of their collets are made in China - only the ones marked "Tuff Pro" are... Although that's now most of the entire line.. As recently as 10 years ago, Royal offered a real first class product, even offering special 5C grinding collets that haven't been spread that offer really tight accuracy for sharpening endmills... Guess that era is now over..
    HTRN
  • krems
    As was expected on a used piece of equipment the collet closer has a slight dent in it and I'm sure it';s causing the poor accuracy. Spindle runs true but when indicating in the collet closer /holder (4 1/2"mt) I'm not able to get it to run true. I'll have to see if I can smooth out the dent. I think the collets are all new. I'll try one thing at a time. Even if I can get it lined up to run true in one location I can mark it for reference. Good idea
    Once I get everything runing true then I can test each collet for accuracy.
    Rich:...nice buy on the used collets. I just looked through a catalogue and these could get expensive if you wanted a complete set.
    Happy New Year from Montana................Krems
  • Rich Carlstedt
    When you talk collet accuracy, first you have to mention.
    Lathe spindle condition/runout
    Collet holder condition/runout ( Note ! also does it still have a key ?)
    Collet condition.
    Assuming all are new, then you should expect about .0005 or better.
    My lathe is old, but has new bearings.
    The collet holder is in good condition BUT I must mount it in only one location (Paint marked !) to get .0001 reading on a .0001 indicator.
    I bought about 80-100 5 C's from a guy quitting busines. they were all used and many duplicates, so i sorted them out by running them in my 5C holder in my Clausing lathe. I used dowel pins and was sort of shocked at the results.
    I found used Hardinges with upto .002 runout, but the average was .001<
    I found like new imports with .005 runout.
    I found the average on all was at .0012 runout. (used)
    I found almost all Imports to have wobble (non-parrallel runout)
    I found most of the Hardinge collets to be more accurate than the others.
    I had Royal, Southbend,Hardinge,Elliot,Lyndex, and others.
    Follow what Evan said about runout mearsuring and check some other sizes.
    Royal is pretty good and I rate them just below hardinge also.
    I do not use Oversize work (over+.001) in a collet, thats how they get damaged.( the larger radius causes the forces to be unsupported ..draw it up on a piece of paper) You are bending the "jaws"
    They will go down to -.005 without hurt ( no jaw bending!). But you may see wobble as parallel holding on the work axis is tapered!
    For odd size work, Thats what the old collets are used for. got a lot of them!
    Rich
  • nheng
    Krems, Technically, they shouldn't be used beyond 0.002" either way. The further you get from nominal the more distortion gets introduced and the accuracy and holding power goes down. Whether or not the collet gets any permanent damage from being "sprung" will depend on the brand and how far it's been stretched. I've gone +/-0.005" many times and a bit more once or twice. Den
  • Frank Ford
    And, it's always possible to get a dud. Admittedly, one shouldn't expect the greatest accuracy with imports, but last year I bought a 3/16" Lyndex from McMaster that was way off - more than .020" if you can believe that. A quick phone call got me a new good one.
    Frank Ford
    FRETS.COM
    Gryphon Stringed Instruments
    My Home Shop Pages
  • krems
    Thanks guys, I thought that they mere supposed to be more accurate than that. The spindle runs true. I suspect that the 4 1/2mt-5c collet closer is the source of the problem. I'll try alligning it up first then try again.
    One more question about collets: If I was using a 1/2 " (.500") collet what range of diameters would be acceptable to use in it...ex......490-.510"...plus or minus 10 thousandths or less / more. Thanks again
    Krems
    Need to know if you have "parallel runout", or "wabble".
    The first is the same all along a pin, the other is worse the farther out you go.
    Collets are pulled-in hard by the closer. If the threads are out of kilter, the drawtube not on-axis, etc, then the collet can get in there cocked, and have wabble.
    Parallel runout would indicate a different type of problem.
    Check for crud or dings in the taper, inside the adaptor, and outside it, and inside the spindle.
    Check that the drawtube rear bearing centers up.
    Check that the threads are not dinged up and the drawtube is not bent.
    Royal is a half-step under Hardinge..... maybe..... A Royal closer and collets ought to be very good, if the closer system was made for that machine.
    If it was adapted by Bubba and Joe-Bob, who knows?
    Per your last question (posted as I posted) about 1/64 range, centered on the collet size is best. They are stepped by 1/64 increments typically.
  • Virgil Johnson
    Use a dial indicator to check your adapter without a collet in place noting the runout. Remove the adapter and rotate 45 deg or so then check again. I was able to get my adapter running within .0003. I marked the location to the spindle with a die grinder so I can out it back in the same relation. Royal 5C's should run less than .001 day in day out providing the adapter/spindle is running true.
