Weight of Brass?
  • Weight of Brass?
    Does any of you fellers out there know what the weight of brass is per cubic foot? I've found everything including the kitchen sink when I looked in the machinery's handbook but still didn't find that. I'm sure it's in there somewhere but I haven't had any luck finding it. 360 brass is what I'm specifically looking for the weight on. Thanks in advance.
    Jonathan P.
    +/- 534 lbs per cubic foot cast or rolled
    http://www.reade.com/Particle_Briefings/spec_gra2.html
      Here is a pretty complete table of densities, including brass. Water is density 1 so just multiply by the listed factor of the material in question.
      http://www.mcelwee.net/html/densitie...materials.html
        Thanks guys. I knew some of you guys would know the answer. Ask and you shall receive. I knew steel is around 489 pounds per cubic foot but I couldn't find the weight for brass. I have some figuring to do now. Thanks again.
        Jonathan P.
