Need some quick math help
  • Need some quick math help
    What is the method ( if there is one) for figuring the radius of the circle below when all I have is the chord length (red line # 2 = 177inches) and the radius segment ( blue line #1 = 12 inches).
    (The blue line segment is on the radius even if my image shows it a little off.)
    My guess annd check method using some graph paper gets me 336 inches, but I'd like to be a little more confident.
    thanks
    Mark
    Using the CSEG program available on my page, we have:
    CIRCULAR SEGMENT CALCULATIONS
    Input whatever data you know; press return if not known.
    You must enter two data items to obtain a solution.
    Radius of segment [0] ?
    Segment included angle [0 deg] ?
    Chord of segment [0] ? 177
    Height of segment (sagitta) [0] ? 12
    Radius = 332.3438
    Angle = 30.8873 deg
    Chord = 177.0000
    Height (sagitta) = 12.0000
    Arc Length = 179.1616
    Area = 1421.1932
    Regards, Marv
      According to my CAD program, r = 332.3+", but there must be a formula....
        The formula is:
        radius=(4.*height*height+chord*chord)/(8.*height);
        where:
        height = sagitta = 12 for this case
        chord = 177 for this case
        The derivation of this formula is left as an exercise for the student :-)
        Regards, Marv
          Here's a handy page of circle math:
          http://www.1728.com/circpart.htm
            Radius of Arc
            Let R= the radius your looking for
            C=straight distance between the ends of the arc
            h= height at the center of the arc
            The radius is given by:
            R=(C^2/ (8*h))+(h/2)
            I believe this is what you want.
            Chuck
              Thanks!
              Exactly what I needed.
              Mark
