QC tool holder
  • QC tool holder
    is this the part i want for the 9" south bend lathe?
    http://www.use-enco.com/CGI/INSRIT?P...PARTPG=INLMK32
    I put it on my 9"er and worked very well, and ENCO's price is the best Ive ever seen, AND the Phase ll has a good reputation for being good stuff...now if youve got the free frt code, you gonna make a good buy! (Jan code is PRFS126)
    Are you already aware that you have to do a little machining on the threaded 'foot?' to fit into your cross slide opening? Just about have to on all the adaptions, but its cast iron and easy to work....
      That is a piston design.....you ought to consider the wedge design instead.
      There used to be some of those sold on eBay which were made in China and weren't too bad.
      If you have access to a mill, you can make the basic tool holders.
