Critique of the HF lathe tool grinder
  • Critique of the HF lathe tool grinder
    They didn't have work and I got today and friday off (I am a part time worker in a machine shop).
    This critique is for those that may intend to buy a Model 46727 lathe tool grinder and considering it only lists for about $165 you get what you pay for. This is to make you aware of the faults I found and should be corrected.
    My tool grinder came this morning and after lunch I took it out of the box and began the assembly. The box as shipped weighed 100lb. The Fed Ex delivered it.
    Before I put the grinder together I turned it on. It had a slight squeal in the bearings so I taped the housing with a soft hammer to center the bearings in the bores and the squeal stopped.
    Next I tried the cast metal quadrant parts on the side of the grinder and found them to be a poor fit. The castings were also somewhat warped. It was necessary to open the slot where the locking handle fits with a die grinder and a bur. It was also necessary to dress the slots where the plastic pins slide in the quadrants to adjust the table angle with the die grinder and a square ended bur. I also found the sides of the quadrants were not flat or at a 90 deg angle so it was off to the belt/disc sander to dress them up. I also scraped the paint off the area where the table sets on the quadrants. I ran a lathe file over the top of the table and found one table to have high spots on one edge that I filed off to get the table flat.
    I then assembled all the parts and tried it out. Before grinding I dressed both wheels. They are very hard and will need constant dressing as they glaze over quick. I pulled one of the wheels to see what grade it is but could not read the printing on the wheel. They appear to be some form of white wheel of hard composition. I then ground some carbide lathe tools and some HHS lathe tools. Both ground ok but I don't like the grade of wheel and will be getting replacement wheels later on.
    I am not a perfectionist but I am a fanatic about doing something right and having my tools and machines in very good working form. I usually completely check over and disassemble, repair or revise any machines or tools I buy to get them to the best working condition posible. It pays in the long run for me as I then have confidence in what I am doing and what I produce and that the tool/machine will perform as expected. This seems to be a good grinder and having used some of the more expensive brands of these grinders for years in job shops I feel good about the HF grinder for me.
    edit: I got mine on sale for the $130 price also.
    Mine should be on the doorstep when I get home today.
    I'd sort of figured it was a "toolgrinder kit"
    I'll report as well...
    "Lay on ground-light fuse-get away"
      It's on sale for $130 now.
      Joe
        You're right about the wheels. I think they're made out of cast concrete or some such compound. I also found the water/coolant valve to be less than functional but I didn't have any problems with castings. As with any of the HF machines, they're pretty much a "kit" that needs refining. All in all, I believe it to be a bargain and worth the price. The alternative is about $800 so I'm willing to put forth a little work to make it a useful tool.
        I just finished building a stand, adding reinforcement and adding power drive to a HF 40" Combo Shear (shear, brake & roll). I'm pretty happy with it NOW. I've got about $40 in the stand and about $60 in the drive. The shear itself cost me about 8hrs. in traded labor. I still need to make some chain guards and panels for the stand. The alternative? About $8,000+.
          Cast concrete you may be right . Ken, that's a fine job you did on the shear. It looks real nice and the chain guards is a good idea.
            My wife bought me that model HF tool grinder about 3 years ago that was on sale then as well. I got a good one right out of the box (lucky THAT time). The wheels then sound like they were a little better composition silicon carbide (green) but they were too course for touching up the final edge. I sprung for a diamond wheel at about $90 for one side. I have not had any problems with mine. A great solution compared to the $800 USA versions. I mounted it to a pedastal stand with wheels so I can move it near the lathe when I am using it.
            CC Ken ...VERY nice job on the shear/brake!!
            Duke Reno / Yankee Metallic Metalcraft
              Hf Kits
              Ken,
              That combo slip roll is a nice machine. I like your stand and power drive. My workplace had one we bought from Enco, about 20 yrs ago. We built a stand for it and used it for all kinds of fab work. The shear was not heavy enough to do much real work but we had a 4' squaring shear so that was not a problem. The brake and slip roll, however, were worth their weight in gold. If I get a chance to get one for myself I will get the 40" one for sure. Our Enco was only about 30" and sometimes was just too small to do the job. The 40" seems to be made of heavier castings.
              Jim (KB4IVH)
              Only fools abuse their tools.
                47 kilos of Chinese metal were shivering on the doorstep when I arrived home from work today. I dragged it down to the shop and assembled it. It actually looks a bit better than most HF stuff in the store. How they can sell these at about $1.30 a pound is beyond me.
                The thing I noticed first is that the RH table isn't level in the fore n' aft direction, it slopes toward the user. Is this deliberate? do I remove the wheel guard that the table hangs from, slot the bolt holes for adjustability and set them up flat?
                Mine came with pale green stones which dressed right up. It runs very smoothly, although it's a bit noisy as it accelerates. Once at speed it's quite quiet. At Cabin Fever tomorrow I'll be looking for some proper wheels for it.
                I got it for $129 plus $10.99 freight, and if you google search "Harbor Frieght Coupons" you can probably find a link to a code which will get you a $10 HF gift card. For $130.99, you can't go wrong with this thing.
                  My wife got me the same grinder for Xmas, it actually looks like a decent piece of equipment, it's quiet and siting unsecured on my bench it's vibration free when running. The only thing I had to do was file down the guide bar on the angle guage (or what ever it's called) so it would slide a little smoother. This is the first time that I have used a tool grinder like this and I must be missing something, the guage only goes over to 45 degrees so you can't set it to grind a 60 deg. threading tool or to grind a shallow relief angle on the front of a bit. To get around this I have made a 90 deg reciprical angle attachment that clamps onto the angle guage so that i can grind shallow angles. Have I missed something obvious that you guys know. Is there a better way to grind these angles.
                  Southwestern Ontario. Canada
                    That's how my tool grinding station is set up.
                    moto, I checked my tables and they are very close to level to each other but leaning to the front as yours are. I don't think it will affect much as you are still free hand grinding and to an approx. angle. It would only move the tool up or down on the stone face.
                    loose nut, I would just make a fixture to hold the tool to the desired angle with the table set at 0. It still won't be as perfect as a fixture on a surface grinder but close enough.
                    EDIT: the two trays under the table will walk off my grinder so to keep them from falling in the floor I put a bungy cord from one side to the other side as seen in the photo's.
                      loose nut the 60؛ tool consisted of two 30؛ grinds with the appropriate side relief set with the table tilted. The protractor set over to 30؛ would get a finished tool with a 60؛ profile.
                        That's true Tinker, but he still has to reset the table to grind the clearance. I don't think I would trust the true angle of the markings on the quadrants anyway. It would be best to set the table with a square and use a fixture to hold the tool with the proper angles designed in.
                          Carl that's just added complications in making a fixture for every type of tool he'd need to use. He does not need any fixtures just a nice square block holder for the toolbit... a center gauge and a bevel protractors nice to double check gradients. Set table to 0؛ for front relief use the guide protractor set at your front angle and dress with toolbit laying on side. Reset table for your side relief and the guide set at 30؛ and do each side. Free hand the end radius allowing for the thicker heel to support the tip on the end and stone. Check with center gauge. I do some free hand grinding of bits allot with chip breakers. Knowing how to grind a tool that works and cuts well is a handy skill. Not all my tools fallow recommended guidelines but will peal steel like a paring knife.
                            I took the green monster partially apart this evening and trued up the aluminum drive plates the wheels bolt to. Mine were nothing like straight, and the backsides were not machined at all. I used an expanding arbor, faced the fronts and backs and the nut seating areas. It runs smoother now for sure.
                              I didn't suggest a fixture for every tool nor did he inquire about that. He was interested in grinding a threading tool. He can do it as you suggested and I agree it would work. My thought on using the fixture is to keep from moving the table settings so much. He would have to set the table at 30 deg and grind each side to the right length. Then reset the table to 5-10 deg for side clearance and carefully grind each side of the V untill it comes to sharp edge on top. With a fixture made to use the slot in the table he could grind both sides of the V with the 30 deg angle and the relief at the same time and only have to turn the block 180 deg to grind each side. There would be several ways to make a fixture for a two step sharpening of a threading tool. Less time sharpening and more time to machine. I got tired of wasting time years ago. But as I have said before, if you are doing it as a hobby it makes little difference but if you are trying to earn some spending money then time is important. Some stuff I do for money and some stuff for fun but I still do it the fastest way I can think of. I guess it's just the job shop attitude in me and it's been hammered in to hard to quit that way of thinking. I guess it was driven into me as a child. One of my mothers expressions was, S--t or get off the pot, and she meant, get the job done, whatever you were doing or she would do it herself. Believe me, you did not want to have her do what she told you to do.
                              BTW, I free hand grind all my lathe tools and drill bits except the threading tool which I have a fixture that I use on my surface grinder that does a perfect job with two movements of the tool bit.
                              The reason I bought the lathe tool grinder is to speed up the grinding/sharpening process and get more satisfactory and repeatable grinds. I set my tables at 10 deg and never move them except for special tool angles which is very seldom.
                              moto, mine ran pretty true but I may do that when I change the wheels out for they did run out some but not enough to bother with now. It's those blasted concrete wheels that I don't like.
