hand oiler rant
  • hand oiler rant
    I have been to every store in town, that might possibly sell hand oilers, and I haven’t found one worth keeping. I have probably gone through a dozen of them already, and I’ve been machining for less than a year. Every time I use one I end up with way oil all over my hands. The pumping mechanism look like something designed and put together by a monkey. The rolled seam ones are twice as bad, not only do they have crappy pumps they leak around the bottom seam. I don’t even want to think about how much vactra way oil I’ve wasted.
    Ok now that I have that of my chest, does anyone know where I can purchase a quality Reilang brand hand oiler or its equivalent in the states?
    For those that don’t know a reilang oiler is a cast aluminum oiler that looks like this.
    -Dan S.
    dans-hobbies.com
    project?
    I had a wobbly about this awhile back- got a couple- home made oilers in the works - coming together slowly- a false start
    or two.......
    any way it is daft to be making oilers but never the less when its done i cant really blame the manufacturer now .......
      The Reilang oilers are exspensive, but great! They are available from McMaster-Carr.
        I just use a hypo syringe with a heavy (16G) needle. Try your local vet
        Just got my head together
        now my body's falling apart
          I have a couple of the Eagle brand. Seem to work pretty well.
          Ad maiorem dei gloriam - Ad vitam paramus
            Hand Oiler!!
            "Every time I use one I end up with way oil all over my hands."
            Wouldn't that mean it was working correctly?
            I also use Hypos with and without the needle for oiling. The oil destroys the plunger seal after a while and I just grab a new one.
            Rgds
            Michael
            Australia
              I feel your pain, or rather, your oily paws! Happens to me all the time! Always have to keep a wiping rag handy when oiling.
                I checked McMaster (thanks mmambro), and man the Reilangs are expensive ($40+); at that price I think I could make one cheaper. Has anyone used the Prolube brand? Enco and MSC both carry the line, so I could pick one up next time I place an order.
                http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=17334044
                -Dan S.
                dans-hobbies.com
                  I have a pistol style oiler I picked up at Tractor Supply Co. it's metal red colored with a 6" flexible tip... was priced under $10. Works great oil only comes out the end of the nozzle. They also have vet supplies like syringes.
                    Groz oil can with brass pump, fixed and flexi nozzle for my Tellus and way oil works well here (NZ$12)
                    If the seam on your cheapy is leaking try soldering the joint.
                    Ken.
                      I've had the best luck with a Goldenrod can (thumb actuated) oiler for way oil applied directly to ways or to lead screws etc., but I have the best luck applying oil to the much-hated ball oilers with a vet syringe and a largish needle. The belt sander took most of the point off rather cleanly but left just part of the original bevel to the tip. You can then just push the needle in and past the check ball in the oiler and put the oil on the right side of the ball. Using ball oilers this way makes them much less annoying. They are just a self-closing oil cup without the cup, so nothing sticks up to snag.
                      I did find that I occasionally have to run a fingernail over the ball once the needle is pulled out to get it to snap back into place. The needle pushes the ball/spring over to one side and occasionally causes them not to snap back in place. The syringes and needles are cheap at the farm supply places.
                      Paul
                      Paul Carpenter
                      Mapleton, IL
                        What I’m noticing is that the cheap oilers (< $10) have really crappy tolerances in the pumping mechanism. My lathe has 21 GITS oilers, that I give a shot of oil each time I use it. By the time I get done, way oil has seeped out from around the piston, and covered the can and my hand.
                        At first I though this might have been a cheap import issue, but I have used 3or 4 made in the USA ones and they had the same problem.
                        lol maybe I squeeze to hard on the trigger. Dad always gave me hell when I help him in the shop; said I always over tighten bolts etc.
                        -Dan S.
                        dans-hobbies.com
                          I have an oiler I bought 30 years ago when I got my first Southbend.
                          Got it from a Link Hardware store (I don't think the chain exists anymore).
                          It's made in Italy by Brevattato. I'd love to find a hockey sock full of them now.
                          I've waited and waited for it to blow out when lubing ball oilers but it hasn't so far.
                          Some of the ball oilers on my lathe are downright rude about taking oil but this old can just keeps on pumping.
                          Seems to me I paid about $2 for it new.
                          Russ
                            i'll second Tractor Supply. i picked up a nice small one there. it was more expensive than the plastic crap you find for $1 at the local wally-world, but it doesn't leak. i also picked up a few oilers at an auction for about $12. well, okay, i got about 30 of them. they are almost all old ones and while four or five of them leak a bit, it isn't like i don't have others to choose from. the auction deal is the way to go if you have a chance to attend a local one.
                            andy b.
                              I've got a bunch of oilers, new and old, Eagles, Goldenrods, etc. They ALL leak.
                              One thing that works is to replace any older cork or fiber gaskets with one cut from Buna-n rubber sheet. Then, goop up where the nozzle connects to the can with a sealing compound like Permatex. Lastly, if it has a pushbutton actuator (like the old Eagles) check any packing material, tighten or add to it.
                              When you're all done, buy one more can that promises to be the ultimate oiler
