Cutting circles
  • yf
    SJorgenson,
    What you described is pretty much how waterjet pumps are built.
    Darryl,
    The pressure washers were run at 40 KPSI and with a fan spray nozzle.
    It takes an amazing amount of pressure to remove some types of grime from New York's buildings.
    Pressure washer pumps at 80 kpsi. Sounds like a way to cut door and window openings through concrete. How would you clean siding with it? Scare the dirt off?
  • SJorgensen
    I'm pretty sure that the first guy to ever build one of these didn't have a million dollars to spend. It really isn't fair of Thrud to suggest laser and water jet cutting without telling us how to build one in our HOME WORKSHOPS. I'm going to throw some numbers out and suggest a way to do it (just speculating.) Suppose you had an 8 ton double acting ram and the rest of the stuff to run it. If this modestly sized ram where used to drive a 1/2" rod in a long cylinder the pressure could reach 80,000 psi. Two rods could work alternately for a continuous output. I don't know if check balls work at those pressures without special provisions but the pressures are achievable. Making the orifice inexpensive and easily replacable could be a challenge. I shy away from sapphires. It would be cool if someone could design one for the home builder.
    Spence
  • yf
    I did some installation work for a guy who once ran a waterjet cutting firm. He mentioned to me that there were some pressure washer pumps on the market capable of 40KPSI that he thought would work great for water jet cutting.
    They were a lot cheaper than the dedicated waterjet machines available then (8 years ago)
    The machines he was using went up to 80 KPSI if I remember correctly. One of the big expenses was the grating that the workpieces laid on.
    They got eaten up pretty quick.
    I wish Tesla and Einstein were both alive today, we could pose the pressure requirement to Tesla, then ask Einstein if theoretically, the water jet could exceed the speed of light. hmm. 50,000lbs pressure is a tad more than my best water pump can do.
  • yf
    How about using a Tesla pump to get the pressure for water jet cutting?
    A lot simpler than the hydraulic piston pumps.
    Someday when I have the time (never ) I have to try that.
  • Doc Nickel
    It's pretty noisy all right. Most cutting actually takes place under water- the cutting table (at least on the unit I'm familiar with) has a variable level tank. You set the parts up "dry", then flood it. That keeps the spraying and the noise down.
    And only 20K? I'm told this one starts at 50K psi, and if it drops down to less than 42K, they pull the pump down and rebuild it.
    If you can make a pump that can push water to 50,000 psi, and find Sapphire nozzles with an .015" orifice, the rest of it- the CNC 2D positioning, the cutting table, and the grit applicator- is relatively easy if you want to build one.
    That does it! I'm off to purchase a 20,000 psi water pump and some cheap towels. I can probably EDM some tiny holes in my carbide boring bars to use as nozzles, hmm. Kidding aside, I've heard that water-jet cutting is noisier than stink, is that true? Is it practical for an HSM guy to build his own w-jet system?
  • Doc Nickel
    Actually, the waterjet creates very little distortion, and even then only on thinner stock. Usually if I get a part "distorted" out of the waterjet, it's a factor of inherent stress in the rolled or extruded aluminum billet. I used to have a problem with the blanks cut from the ends of sheared barstock "cupping" a little, but the blanks from the center of the bar were dead flat.
    The 'jet actually applies very little force aginst the material- it's basically just a vehicle to drag the abrasive past the kerf.
    Laser cutting typically doesn't distort the thinner materials, as there's less loitering time. Cutting the thicker materials usually does induce some heat distortion, but usually a little less than a CNC plasma cutter.
  • Thrud
    I like water jet and laser cutting. Laser cutting does not warp the material at all (a good thing to remember). Water jet leaves a frosted surface on thick aluminum (the cuts) and slightly distorts the Aluminum from the pressures involved.
    Blanking on a punch press distorts the edge of the metal considerably.
    Cutting by torch or plasma can change the material properties in the heat affected zone.
  • L Webb
    Easiest way is to blank them out with a punch press. But if you don't happen to have at least a 125 ton punch press and the tooling, then you can trepan the circle easy enough on a lathe. The biggest mistake people make when trepanning is too fast of speeds. The plate must be held in the middle securely and plenty of coolant.
    I'd go into more detail but I can't give away our secrets.
    Les
  • yf
    Simplest cheapest circle cutting attachment for the torch is, electrical "bug nut" (splicing bolt) with nail brazed on head.
    Bug nut stradles torch tube and nail rides in center punch mark. Adjust radius by sliding bug nut on torch tube.
    Could also hose clamp, bent nail to torch tube but its not too solid.
    It helps to use some kind of turntable, so torch remains stationary, prevents fouling hoses.
  • SJorgensen
    Ultimate cheap circle cutting technique; Nail a square piece of plate aluminum or steel to the lower end of a 2x4 and use duct tape to tie it to the frame of the rear car door. Drive around with the piece in contact with the pavement. Remove when the piece is the appropriate size.
    (As an alternative buy a hole saw or even better a trepanning setup (not the skull version.))
    Spence
  • rbregn
    Did you use a circle cutting atachment on your torch? With one of them and a clean tip and "steady hand" you can get surprisingly good results.
    Rob
  • Joel
    Thanks for the good ideas.
    Steve, I only need a few, and they are for me. I have had mediocre results with a torch, but will apply your tips and see if I can do better.
