I'll keep that in mind if i ever *need* a funky tap. Right now, i'd just be making them to show off. (Which in reality means taking perfectly good drill rod and turning it into junk... )
Looking thru some pictures tonight and found this drawing which shows the relationship of the ball end mill to the tap for a 5 flute cutter to get the hook.
As they say a picture is worth a 1,000 words.
BTW it shows a LH tap.
scrapped the old taps. hardened them and tried but they're garbage. made new ones as per advise here, like Rich and John pointed out I had too much thread. here's some some shots of the new ones
lynn, I turned the taper in the lathe prior to threading.
greg , that's what i do, based on the logic rake is rake and different metals like different rakes
before heat treating
finished product, will be the nut for a turnbuckle for a finger brake
i was going to get fancy and grind the flute, but turns out theres no need, worked well with a bit of stoning. i used soap with the heat treating, sort of stopped some scale.
thanks again guys for the help on this, couldn't have done it otherwise
