Hello I am interested in building a table that is almost twenty feet long. It is made from two inch .120 tube and the tilting table mechanism is made from .065 3/4 x1.5 inch tube. Any hints on jigging it so it stays straight. I have a piece of 4 ft. by 8 ft. steel plate to build it on. Thanx Audrey
Long Table
audrey:
We used to build stuff like this just on the concrete slab. You can snap layout lines on the slab and work from there if you like. If you have a smooth flat one you are laughing. Build it upside down. Top first, then add stuff to it making sure it stays square - then flip it over and its done.
Easy. Good luck!
