I'm going to be doing some internal threading on the lathe and decided I'd add to my slowly growing stock of indexable tooling. I bought a Carmex 08-IR/L-A60 internal threading insert with screw and wrench from MSC. I'm going to make the tool holder as this is hobby, not business and $70-$120 is a lot of $.
I have the geometry worked out in CAD for the tool holder and I was wondering about suggestions for the metal stock to use. I have seen where some people have been using key stock. Is this OK?
The tool holder will be made from 3/8" square stock (it's a small insert 48-16 TPI, 3/16 IC) and will only extend an inch at max.
I don't plan to harden it but I would like to make a holder to last years.
Would hot rolled be better than cold rolled to keep distortion down as most metal will be removed from 2 adjactent sides. Or a pre-stress releved grade? I already have a supply of 12L14, would that work well?
Thanks,
Kevin
[This message has been edited by brunneng (edited 04-01-2003).]
Thanks,
Kevin
