For todays project I have a 17" long piece of 25mm diameter O1 steel that needs a hole thru it. I used our like new Austrian made EMCO (NOT enco)maximat super 11.I faced both ends, centerdrilled, started the hole with a 15/64 stud length drill, drilled with a long 15/64, reamed 1" deep with a .250 reamer, and then used a 11" long 1/4" drill from each end. When the holes met in the middle it looked like they walked offcenter .02-.03". I drilled in 9 1/2" with the 1/4 drill and the bores blended together but you can see the hole is not straight when you hold it up to a light. Final size of the hole needs to pass a 3/8" shaft.
Any good ideas on how to make the hole straighter as I approach final size?
