We have aquired an older Jet 280 bandsaw and have seen once or twice how to operate the blade welder, but not quite sure how to go about it without some guidance.
Anyone can give me some tips to save me some headaches and speed up the learning curve?
Like a general procedure I can follow? Using the welder and tension adjustments, the 'momemtary' function to temper the weld (is that right)?
Any help is greatly appreciated- I have no blade on it now and I need to use it!
Thanks in advance-
Thanks in advance-
