Just finished installing and levelling the new Grizzly mill, so now it's time to start collecting data on rebuilding the old JET.
It's worn, but there's lots of life left. It's Vari-drive type mill-drill, and the whole belt assembly needs a good going-over.
I've heard of switching to some sort of polymer or elastomer belt can make the thing run smoother. Any opinions on this? Who makes such a belt? Should I bother, say, having the pulleys balanced?
On the quill- if I replace the bearings, do I need to buy real live Class 5? Do I source them from JET or from another supplier? Should I bother trying to regrind the spindle collet taper?
Is it worth replacing the hollow cast-iron column with what would probably be a very expensive rod of solid steel? Mild steel, cold rolled or chrome-moly? I've heard it suggested that the hollow stock column be filled with mortar or concrete to add stiffness without the cost- any thoughts?
Considering that I'm in Alaska, and tool rebuilders are few and far between, if I have a worn saddle or want to recondition the top of the table, where do I start?
Any advice welcomed.
Doc.
Doc.
