Hey Guys,
I just thought I'd share a couple of my recent projects with you all. I modified my 6" rotary table by mounting a spare 4" 3-jaw chuck, according to an article in MW/HSM. It works great and I've machined annular o-ring grooves in eight stainless steel (304) flanges with this set-up. It's also a great time saver when drilling bolt hole circles too. Nothing new here, but I didn't have this capability before.
I also began a repair on an 80-tooth cast iron spur gear for the lathe. It's a spare gear with two broken teeth. Again, I got the idea from a recent article in MW/HSM. The differences in my case was that I decided to do this on the spur of the moment and did not have brass/bronze brazing flux. So, I tried some silver brazing flux with phosphor-bronze rod and it worked fine. I don't have milling cutter to cut the new teeth, so I'll use a similar gear (same tooth geometry) as a master and file the new teeth by hand. I know, this is pretty exciting stuff. I learn something new everyday.
Regards,
TIM
Regards,
TIM
