hey, just want to pic your guys' nuggets; on my 12" lathe, what size, in your opinion is the ideal three jaw, and ideal 4 jaw size? in regards to the three jaw, i obviously wouldnt want to run a 12" chuck, because i would never be able to open the jaws. just would like to see what you guys are running, or think i should run before i buy. also, if anyone has some chucks for sale, i am intereste, if they are a 2 1/4 threaded back plate type. finally, that is also a point of confusion, as enco offers plain back, and then bison set-tru. i like the bison set-tru, sounds like a good idea. would it be beneficial to buy one back plate then bolt and unbolt when i need to change chucks? or two back plates where i would unscrew and remove and replace with other chuck assembly?
steve.
steve.
