Prior to the last year, the only taps I had used were to chase threads in an existing threaded hole.
After reading your collective wisdom ( and other sources) on tapping techniques / do's / don'ts / etc, I started using some taps to cut new threads for various projects. My latest is tapping 3/8-16 holes in a 3/8 mild steel plate welding table surface for fixturing various items that I weld together.
I've broken 1 tap so far, and I think I understand why ( tap not started perpendicular to the plane of the surface, and I turned it too hard when it started to bind )
I acquired a large machinist toolbox a number of months ago which included a lot of high quality taps. How do I tell if a tap is "sharp" ? Is it a feel thing?
Is there a way to sharpen them? ( If so, is it wise to so?)
Thanks
Mark
Thanks
Mark
