I'm trying to make an optical center-punch with the lathe, so I want to approximate a lens shape on the end of some some cheap plastic (acrylic?) rod that I got from Tap plastics.
This doesn't need to be great. Realistically just a non-magnifying flat on the end of the rod would work OK, but I figure someone other there might have a bright idea on how to approximate a proper lens shape without a CNC machine.
So far I've made a couple trials freehanding with a file roughing out an approximate lens shape, and it sort of worked, although not very magnified and it was somewhat distorted.
Maybe make a CAD drawing, printing out to scale, and using that as a gauge?
First things first though, need to figure out the refractive index, and then figure out how to calculate what the desired shape is supposed to be for some magnification.
Any ideas floating around out there?
