Which of the two scenerio consumes more fuel. This is for a carburated engine with no computer and nothing fancy.
1. The vehicle is stopped. The engine is idling at 600 rpm and the accelerator is not depressed. Transmission is in neutral.
2. The vehicle is going down a hill in 5th gear. The engine's rpm is 2500. The accelerator is not depressed.
In both cases, because the accelerator is not being depressed, the butterfly valve in the carburator is fully closed. For sake of the argument, the fuel pressure and the atmospheric pressure can be assume to be the same in both cases.
I need your help to resolve this debate.
Albert
Albert
