A decade ago I made legs for a butcher block kitchen island out of 3.5" EMT steel conduit, brush finished on the 6" belt sander and then sprayed with clear water base urethane. The finish held up well except where chair legs, etc, bashed it.
It's now refinishing time for the top & legs, and I was wondering if there might be a better clear finish than what I used. It was tough to do because too heavy a 1st coat would result in a light rust under it. I shied away from an oil finish because I thought it wouldn't be as clear & bright as urethane. Any ideas out there?
