Id be boring and go with the 350. All the $$$ youd save on fancy cranks and all, you can spend on some heads which will get you the torque you are looking for. For example, some 305 HO heads on a 350 with dished pistons will give you lots of torque, especially with a long runner intake. The 305 heads wont flow enough at high RPMs to break anything either
The TPI fuel injection systems from the 80's have really long intake runners (longer than possible with a carb) and produce 300 'lbs of torque from just off idle to 4500 rpms in a mild 350...that will get you up a 45* slope pretty quickly. Another option is an old canadian cast iron 2 BBL intake and carb with a 1-2" spacer.
The canadian intakes do not have the EGR and flow better. All the circle track guys around here grab them up. I can get part #s if you need.
I think that making a small bore/long stroke 350 would be neat, but would not be the best or least expensive way to meet your goals. Head, intake and cam will get you where you want to be.
