Belt sanders we built
  • #16
    I liked Lanes table and platen addition to this little sander so much, I cobbled myself one up! Have had quite a few requests for copies on the sander (Michael, I,ll need your email), so thought I would share a couple pix of the platen/shelf that I came up with that you might want as an addition (See what you started George!)
    I did like Lane suggested and took a piece of cardboard and trimmed it to the rough shape I wanted, transferred it to some .250 plate and then cut it out on the bandsaw. Had a piece of 3x3x3/16 angle that I trimmed up for the table, took bout hour and half. I've checked it out already 2-3 times today and its quite a nice addition.
    • #17
      http://www.balconesforge.org/techarticles/sander.pdf
      Here's one I built a few years ago...
      • #18
        I hd to say you did a great job of that. I have a small 2 inch belt linisher sander im my machine shop, and have recently bought a good industrial 12 inch disc with 6 X44 inch belt combination , this should do me for anything I need.However as a project the idea of making one is a big turn on as this looks within my capabilities and looks fun to do well done again!! and kindest regardsAlistair
        • #19
          Good job! Looks really nice. I have to put one of those on the to do list.
          • #20
            Hi could you show me a better view of the top end and tracking please Alistair
            • #21
              Look at georges 3 d pictures he drew. Real plain in his model the screw pushes the bar in and out so the top puller tilts a little to track the belt . Lane
              • #22
                I have been meaning to build your sander!! I been wanting a knife grinding belt sander for sometime and I found your plans that you posted somewhere on line. It was a crappy copy of what you posted. I have the plans saved.
                i have the motor and the base but just havent dont anything with it. Glad to know your a member of this fine group.
                Its amazing what a good belt sander with a good belt can do!
                • #23
                  Alistair, see if this helps any.
                  • #24
                    George:
                    A quick queston. Is the 14 3/4" dimention for the "spine" for a 42" belt or a 48"? If for the 42" would you just add 3" for the larger size?
                    Thanks,
                    Rick
                    • #25
                      Originally posted by DR
                      .............................................Anywa y, I recommend these type grinders. Mine will never get bolted down (unless I get a couple more). Today I used it by the lathe and across the shop at a mill.
                      I thought of my Wilton 2x72 belt grinder like a writer thinks of a conjunction. You can do things with one of these in seconds that would take hours to do on a lathe, mill, shaper.....etc.
                      And now, if I might take this auspicious occasion to bring you a wiki.
                      http://en.wikipedia.org/wiki/Grammatical_conjunction
                      • #26
                        This is my rendition of his design pics and drawings here
                        • #27
                          Well, as long as we are ripping off and duplicating, here is one that might be worth stealing some ideas from. There is a neat belt sander at 6:48 in this video. 4 pulleys, articulated, removable platen, removable table. Actually 5 pulleys - one above the main drive wheel to add some support when platen is removed. I think it was made by Delta/Rockwell. Looks like Frank ford has a similar model. Don't think you can get them anymore. Enco 163-4512 is the closest I have seen - and it would need all the modifications (except adding a disc sander) undone.
                          The one in this thread lacks the useless covers and guards that get in the way of using the versatility of such a machine (and are sometimes integral parts of the structure) so would be easier to modify.
                          • #28
                            Please Realize These Are Belt Grinders,not Sanders!!!!!!
                            • #29
                              OK, I give up. What's the difference?
                              Is it like a black bird and a raven sort a thing?
                              --Doozer
                              DZER
                              • #30
                                I built one like that one 35 years ago and its still going. Plans and pics here
