Four easy pieces (1/4)
  • Four easy pieces (1/4)
    Summer of 2005 I acquired a large bucket of round to-its and finished four of Elmer Verburg's engines that appealed to me.
    Because amateurs are attracted to the ease of construction of wobblers, these engines have gotten a reputation for simplicity. This design overcomes that by including such refinements as:
    double acting - piston powered on both sides of stroke
    reversing gear - note the small reversing lever at the top of the engine
    Also included is a crosshead which significantly reduces the wear on the cylinder.
    Both cylinder and standard are aluminum and I had some galling problems early on. In retrospect, the standard should have been made of steel. Nevertheless, with some moly anti-seize, the engine now runs just fine.
    <post continued below>
    Regards, Marv
    Marv nice work!! I took a peek at all four engine threads. I have heard of Elmers Engines but Not real familiar with them. They look like they combine the simple with inovation to make them more interesting thanks for sharing.
    Tin
    Ad maiorem dei gloriam - Ad vitam paramus
