Cross Slide Screw
  • Cross Slide Screw
    Does someone know what the Thread size of a Clausing 13X36, 1300, Lathe Cross Slide Screw and Nut is. I have a lot of play in my Cross Slide and may have to make a Nut for it.
    The whole is greater then the sum of the parts.
    I think they're the same as Atlas--1/2-10 LH.
    Forgot to mention: It's acme thread.
    Have you tried to adjust it?
      My Clausing 6300 is a 1/2" 10 tpi. The screw and nut were both worn out. I got a length of precision acme threaded rod from MSC and made a nut to fit it. I cut off the section with the old threads and silver soldered the new piece in.
        I can see the end of the screw that goes in the taper attachment and it looks larger than 1/2' maybe a 3/4 or 5/8.
          Yeah, I was surprised that Mike said his was 1/2". The Clausing 5900 and 6900's have 5/8" x 10 TPI Acme crossfeed screws -- I thought the 6300's
          were the same.
          In any event, the 1300 is a whole different animal, so this doesn't help Backyard anyway, but he posted his question on the Clausing lathe group
          yesterday, and probably got a response by now...
