Mill update: Chip shield and Xylotex heat sinks
  • Mill update: Chip shield and Xylotex heat sinks
    I have made a chip shield for my mill to keep some of the mess under control. It's Lexan and super easy to remove and replace. It lifts off and on and is held in place by gravity only. Quick and easy to clean.
    These are the driver modules . They are single axis Xylotex modules. I chose to use individual modules because it is cheaper to replace just one if something goes poof on an axis.
    In my opinion they do not have adequate heat sinking. The sinks are too small and they are fastened with adhesive heat sink tape. It has about the same heat transfer properties as a dry heat sink in contact with the chip, which is to say not very good. The only advantage is that it is easy to assemble and requires no heat sink mounting hardware.
    I took off the old sinks and cut up a CPU heat sink to make replacements. They are mounted with the hold downs and arctic silver heat sink grease. On average that will give about 20 times less thermal resistance than the as provided heat sink.
    very cool Evan
      Nice job on the heat sinks and lexan enclosure. Your mill is really impressive looking! What kind of feeds and DOC is it capable of in aluminum?
        Nice work as usual,too bad the chip shield couldn't have a bottom in it huh?
          Evan,
          That's not Lexan, that's some other kind of clear "plastic" material !
          Thanks for the tip with the swarf shield(s), you gave me a good idea.
          Lenord
              Lenord
                Steve,
                With that end mill on it now it will cut about .100" x .375" at around 10-15 ipm (roughing). It will climb mill the same cut at about half that rate.
                  Yeah, I'm liking that! Slick idea with the tilt up. (And the individual drivers.)
                    Evan, I can't decipher the second picture -- it looks like you've lifted the Lexan shield off the table, and laid it on the toolmaker's vise.
                    Is it hinged somewhere? I don't see hinges?
                      I just lifted it off and propped it up against the mill to give an idea of how it fits around the table. It has no moving parts.
                      The lexan panels are really easy to replace. Just a few screws and they come off and the hole locations aren't fussy at all. The panels are trapped between aluminum angle and strip all the way around the bottom.
                        auesome, looks like it sits on the angles at the end of the table....very slick, thats what i need to do....49" table may be a bit hard to do tho....
                        AKA BUGPAC.......
                          That's what I thought at first -- Ken confused me
                          Nice job Evan! You need to get it dirty
                            Looks good Evan! Reminds me...I have to get back to my CNC R/T one of these days. Got so fed up with the problems with the driver board...I threw the works under the bench til I get feeling better again. Jeff is getting the driver board back to check it out himself. After the fifth email with the same old "bad ground" diagnosis....I put the manual crank back on it
                            Russ
                              Russ, I thought you had that rotab working at one point? Did you smoke your driver board?
