OT: Where to find replacement home HVAC A-Coil
  • OT: Where to find replacement home HVAC A-Coil
    that fits correctly and is reasonably priced. It's a York unit.
    Mine's been leaking and my original plan was to replace the entire system but a recent downturn in the old bankroll prevents it for now. I've been recharging each summer but friends tell me a new evaporator/A-coil isn't a lot of money, especially if I do it myself. I've been Googling but haven't found one yet.
    I went up in the attic this morning to verify that it is leaking and to take measurements of the existing (ratty looking) unit. I took off the data plate with the model/serial numbers as well.
    Thanks for looking.
    Check your local HVAC supply house - should be listed in the Yellow pages.
    HTRN
    EGO partum , proinde EGO sum
      Don’t forget to take the official card that shows that you are a genuine certified trained licensed air conditioner repairman. Without it the dealers around here are not allowed to sell you anything! This is to prevent you from releasing Freon in the air and destroying the ozone layer.
      It also insures the your friendly conditioner repair man will have plenty of work.
        Check ebay, a number of wholesalers are sell units at attractive prices. One of those house should be able to sell you just the "A" coil.
          There should be a"Johnstone Supply" in your area, they will ups one to you. I have used them in Jackson, Ms and San Diego with good results. The only connection I have with Johnstone is as a customer.
          re
          Herm Williams
            re
            Ditto
            Scott
              Will do...thanks fellers!
