My new horiz. Band saw is still giving me fits. My latest problem is slow cutting. The slow cutting is caused by the very low down pressure I have to use to keep the blade from “binding” in the work. Once the blade stops and is bound to the part, the arm has to be lifted to free the blade and permit it to start moving again.
On the arm is gage that regulates the amount of down pressure. The gage reads from 0 to 25 with 0 being no down pressure and 25 the maximum down pressure. I was cutting 1 inch square aluminum bar stock and it took almost an hour to cut thru the stock. I had to have the down pressure set on 1! If I set the down pressure on 2, the blade would bind.
The coolant that was removing the “chips” was being discolored by the exceptional small “dust” that was being removed. I was using a blade with 8 teeth per inch and the blade speed was the highest for the machine. The rollers and guides were sent as close to the work as possible. I don’t have any idea on how the increase the down pressure to make faster cuts without the blade binding.
Appreciate any assistance. Thanks.
Bill
Bill
