Tool grinder?
  • Tool grinder?
    I just traded my old Rong-Fu mill/drill for one of these import tool grinders in like new condition. It looks just like this one from Enco. The brand on mine say KAO Ming.
    http://www.use-enco.com/CGI/INPDFF?P...MITEM=121-1755
    I had no more use for the mill/drill after buying a larger mill so I traded it off. I am not sure how to run this new machine so I am looking for a place to get some info I didn't get a manual with it either. I am pretty lost about grinding so I need to find some good reading material. I don't even grind my own lathe bits I always used carbide inserts, but I want to change all that and do some learning. Can someone point me in the right direction?
    Thanks Mike
    This is Sir John's CD on T&C grinders, it has all the information you will need.
    http://cgi.ebay.com/Tool-and-Cutter-...QQcmdZViewItem
    Jim H.
      Here a short page on cutter grinding.
      Hal
      http://www.hanita.com/hanita_protected/tec00016.htm
        Thanks for the info that is a good site and Sir John just got an order. He should get a kick out of my Ebay moniker.
          That Hanita page is really good Hal -- thanks.
