Can't wait can't wait...
  • Can't wait can't wait...
    I just ordered a mill and lathe package from Sherline.
    Was going to order a Smithy but my girlfriend talked me out of it and convinced me that seperate lathe and mill are best for what we want to do.
    Personally I think it's because she's planning on walking out of here with the lathe when she dumps me.
    But anyway... As I said can't wait for it to get here. Got a space cleared out in the living room for the work bench, got the outlets wired up, got the material racked up under the bench.
    Hopefully I don't have a stroke when it arrives.
    Plastic Operators Dot Com
    I have them both and do like them as long as you don't try to force them to do more than they are made for. The riser blocks for the lathe and the mill are nice to have. Gives a little more on the size you can work on.
    You do know that there is some assembly required before you can make chips. The book and instructions are pretty good.
    Glen
      I assumed so, based on other industrial machines I have worked with over the years.
      I intend to mill plastic on these... mostly HDPE, Styrene, styrene alloy and maybe a bit of polycarb. So overworking is not an issue, I hope.
      We're both *really* into building and collecting models of Japanese Anime Robots (mecha) and there is a wee market for "customizor" parts. What we're hoping to do is first and formost make custom parts for our enjoyment and possibly make some money on the convention circut.
        I think you'll be very happy with the Sherline machines. Having the seperate machines will be a great advantage, and Sherline's quality and support are excellent. Given the scale and materials you'll be working with, you made a great choice.
        Todd
          Don't worry you can pretty much work in any material its just some people tend to try to squeeze the extra 1/4 inch in or try to take to big of a cut.
          Glen
            I hope you got the rotary table to go with the mill. It's a nice one, and it really pays for itself.
            I'm sure you'll like your outfit. I've had my mill for several years, and I've had a lot of fun with it.
            Roger
              I have the cnc rotary table it is the greatest. it did pay for it self the first 2 months I had it doing repeat holes and layout.
              Glen
                No, we didn't get the rotary table nor any sort of CNC option... Just getting the metric DRO was expensive enough.
                  Yeah, yeah, yeah.... Machines good.
                  So tell me more about this girl that likes lathes and machining.
                    She's a machinist who happened to be slumming in a plastic factory because the shop she worked at closed. I taught her plastic, she taught me machining, I think we're on to somthing here.
                      Does she have a sister? ....
                        Two sisters??
                        Scott
                          Yeah but neither of them are much into machining. One works for Valvoline and the other works at Tractor Supply.
                          Meh.
                            Tractor Supply works for me, Scott can have the oily one.
                            PS. Send picture of TS farm implements in stock!
                              I showed her this thread she laughed her butt off. Now hopefully we can both keep our sense of humor when assembling everything.
