Barrel Sw. Woes
  • Tink
    TREE My Man,
    Got home tonight, and there was a fax waitin for me from Rockwell with the correct wiring diagram on it, as per an e-mail to they're company last nite. Thank-You ever so much for all the help. Ya got the ball rollin for me
    Take care my friend, and don't hesatate to holler if'n YOU need anything!!!!
    Tink
    BTW, You don't drive a PSD Ford, and hang out @ F.D.Com do ya??
    Thanks, and have a GREAT day Tink
    [This message has been edited by Tink (edited 11-26-2001).]
  • Tree
    Tink; I have not been able to find what you're looking for but I am not through with my search yet. Don't give up hope. Check back here tomorrow-maybe I'll have something for you. Tree
  • Tink
    Tree;
    Thats what I'm looking for. Thanks a zillion!! I just spent the last hour searching the AB site, and I couldn't even find what YOU sent me. Kinda dense i guess .
    Can I trouble you for one more favor? The 2nd link you sent me only shows the drum switch having 8 lugs. Mine is a size#1 with 12 lugs. Do you think they have a wiring diagram on the Bulletin350 size 1 switch with 12 screw lugs? I hate to keep askin favors, but I simply can-not seem to find what you'r findin.
    Thanks again TREE
    Tink
  • Tree
    Tink; Sorry about that-not paying attention. Try this link instead. Tree
    http://domino.automation.rockwell.co...LE/350-5.1.pdf
  • Tink
    Toff;
    Thats a darn good idea!! Might just have to do that. Looks like TREE is getting me squared around though
    TREE;
    You da Man!! Back to AB web site I go..
    That's exactally the "DRUM" switch I've got, unfortunatly that link you provided me with only shows wireing diagrams for the interlocks. My switch doesn't have one , BUT you've shown me that it's on the web, and now I can go searching for the main wireing diagram. Thank-You so Very much for the link. I know it wasn't easy to find
    Take care my friend!!
    Tink
  • Tree
    Tink:
    I believe this will help you with your problem-it's from Allen-Bradley's website. (Note-in my experience these are usually referred to as "DRUM SWITCHES" maybe that's why you couldn't find it.) Hope this helps. http://domino.automation.rockwell.co...LE/350-1.0.pdf
  • toff
    Hi,
    Been there myself. I found a local electric motor repair shop and when they found what I was about, one of the guys there stopped at my place and fixed it. Total cost not much.
    Luck
    toff
    To know by reading is different than knowing by doing. OR:
    What you have going into a situation is knowlege..What you have coming out of that situation (providing you survive!) is wisdom.
  • Tink
    Roger that SGW. I'm just not smart enough to figger out which six screw lugs on the switch will accomplish that task. The previous owner had all the jumpers removed so's it would work with his single phase motor, and my brain is MAXed out tryin to figger it out.
    Thanks for the come-back though!!
    [This message has been edited by Tink (edited 11-24-2001).]
  • SGW
    Briefly, what you want the switch to do is swap any two of the 3 wires. But maybe you already know that.....
  • Tink
    started a topic Barrel Sw. Woes
    Barrel Sw. Woes
    Mornin All!!
    When I aquired my lathe a few mo's. ago, the motor was missing. The previous owner had an old single phase on it at one time, but it was gone when I got it.
    I had several 3ph. mtrs around, so I put one on the old girl(1922 W/S #4 Turret Lathe), and made a RPC out of another.
    Well anyway, to get to the point,,Sometime during it's life, somebody has put a Allen-Bradley barrel switch on the old girl.
    Theres a paper tag, inside the cover, but theres not enough of the tag left to read the schematic part of it. All I can read is "Bulletin 350-B_A and size#1.
    I've got the old girl spinnin the right direction, but I can't, for the life of me, figger out how to Reverse her ??(still spins forward if I through the lever in reverse)
    Theres 12 Screw lugs in the switch, and several jumpers. I've spent hours with my ohm-meter trying to find the correct lugs to hook the Line-in, and Line-out wires .
    Can someone send me a schematic or a pic of one? I've searched the "Allen Bradley" web site, but came up empty handed. Any help would be GREATLY Appreciated!!
    A Million Thanks To All!!
    Tink
