Last 4 picture`s to night
  • Last 4 picture`s to night
    glad ya made it home safely Lane
    Glen
      Well three more of us made it home also. Glad you made it safe Lane. Thanks for the pictures.
      John Burchett
      John Burchett
      in Byng OK
        that miniature mill looks amazing :O
        how where the collects/ various small parts made?
          The mill is but one example of the fine work Lane does. He won't brag it up, so I will for him. It is scratch built, with no castings used.
          More details here;
          http://www.cp-tel.net/mary/Lmill.htm
          Jim H.
            two of his other items that where at the show are in one of my picture threads. amazing work
            Glen
              That is amazing, very nice work Lane, what did you use to load parts up with --- Tweasers? You coulda really used that mill to build that mill I bet, but then you wouldnt of needed to build one.
                Beautiful Snow Engine -- just a guess from the paint, is that the model from the cover of HSM?
                Lane, I've marveled over your Bridgeport model before -- it's just amazing.
                I'm assuming you milled the body and knee out of a solid block?
                Does it have a backgear?
                  The Snow engine is the one featured in the HSM build article. It is much more impressive in person than in print.
                  Doug Kelly, the builder also had a very nice freelance barstock side shaft mill type IC engine on display. He is considering doing another build article on that. I would encourage him to do it. It is just as nicely done as the Snow.
                  Jim H.
                    Lazlo no the column and knee are welded construction. The column is a piece of 4 inch square tubing and the kneeis welded up 1/4 and1/2 inch hot roll plate all stress relieved.
                    And no the parts werent as small as some people build . Easy on South Bend lathe and BP.The mill is 24 inche tall.
                      Lane,
                      how about some explanation of the photos please?
                      For example, wondering what the first engine is - atmospheric type?
                      Second engine?
                      Thanks!
                        Really nice work..Absolutely amazing.
                        Rob
