Miniature genset (pics)
  • Miniature genset (pics)
    Recently, I finished the PMR dynamo kit and it turned out nicely. I'm powering it with an Elmer Verburg design two cylinder marine engine. An airbrush compressor provides enough oomph to light a small bulb. I'm running it a bit slower than recommended so the open circuit voltage is only 5 volts instead of the 12 volts PMR says it can generate.
    Here's a closeup of the dynamo itself.
    and a view from the drive side.
    The dynamo kit is a nice starter kit for the newbie. No complicated machining and relatively inexpensive (~$45).
    Regards, Marv
    Shades of "Trustee from the Toolroom"
    Nice work Marv.
      You know, John, I was thinking of that all day as I put it together. Now, if I only knew of a ship with a concrete-encased box full of money and jewels.
      Regards, Marv
        Marv,
        Nice job, I have been thinking of doing that one myself. Just need to get off of my duff and order the casting.
        I notice nothing to indicate scale in the picture. Can you tell me how big it is? (LXWXH) Thanks.
        Paul in NE Ohio
          Dynamo
          Marv
          Elegant projects, the Engine and Dynamo. Next step should be the addition of a long flat belt drive.
          JRW
            Nice work Marv.
            Don't give it away. At someone else's suggestion I bought a copy and am on about page 35 !! This guy Keith Stewart would make me a good neighbor
              Picked the kit up at NAMES and it looked nice. Now I have to get around to its. Along line real nice looking job, on both engine and dynamo
              Glen
                Originally posted by PHiers
                Marv,
                Without actually going out to the shop and measuring it, I'd say it's roughly 2 x 1.5 x 1.5".
                PMR now shows the dynamo as "out of stock" which may have something to do with the fact that somebody on Ebay is selling completed dynamos for $180.
                Regards, Marv
                  Thanks for the info Marv.
                  Heck yours is probalby nice enough to bring 280.00 on ebay.
                  Paul in NE Ohio
                    Penn Tool Co. sells a lot of the PMR kits for less than PMR does...
                    Edit: Just checked, and they have 20 of the PM Research Kits, but not the dynamo.
