Quick change boring bar, alloy question
  • Quick change boring bar, alloy question
    I am making some sleeves for the bearings on my ring roller as per Roger's suggestion in my ring roller thread. I snooped around my junk pile and found an old defunct automotive generator that has no further use so I dissected it and cut up the casing to make a couple of sleeves for the idler bearings. This has the dual purpose of protecting the bearings and making the rollers wider.
    As generator housings are not welded at the seam I had to weld it up and this made turning more difficult, requiring a carbide tool to rough it down. I needed a good way to hold it for the inside cut especially and since I am working with an ID of about 4 inches a simple solution came to mind.
    I normally use a spacer anyway to bring the tool holder on center and with this thicker spacer only had to drop the tool holder down a bit. It does a fine job and I found it also allows a lot of flexibility in offering the tool to the work for other cuts.
    Now the alloy question: If it weren't for the welds this old generator housing is made from some sort of steel that turns about as nice as it gets. Since it isn't turned in the first place it can't be for that reason so I assume it must be the magnetic properties. Does anyone know what alloy is used in generator housings?
    Evan,
    I think it would be soft iron as that will not become a permanent magnet.
    Peter
      It might be mallable iron, in which case the heat affected zone from the weld will be hard and brittle.
        The same alloy as transformer plates?
        Gene
          Transformer iron is usually a silicon alloy and is fairly brittle. I don't think it's that. This stuff turns like leaded steel with a superb finish.
            No idea what alloy it is Evan, but when I was at school I remember parting off a ring from a car starter motor and using it as the outer ring on a gyroscope that I made - the rotor was steel, about 2.5" diameter, and an inch thick; worked really well...
            Ian
            All of the gear, no idea...
              Anneal/normalise "ring roller" steel
              Deleted/edited-out
                If it were a leaded alloy, it would not weld well. They tend to produce very porous welds.
                Jim H.
                  ring roller manufacture
                  Deleted/edited-out
                    Sounds like you're building one macho ring roller The wheels on mine arent near that size and I can roll any diameter size circle I want if the material is long enough.
                    By the way, if you're putting pikes on your iron fence make sure they're low enough you can clear them on the run if BearDog allows something in the yard you don't want!
                      Oldtiffie,
                      I think you misunderstand. I had to weld the seam in the case as the case was not welded at all. Many generator housings are just keyed together at the seam to hold the shape. And yes, I did stick weld it with mild steel rod. The welds weren't all that hard but compared to the machining properties of the housing they are. I only used the carbide tool to rough down the weld on the inside where I couldn't easily grind it. I use C1 solid carbide for that purpose as it can withstand interrupted cuts very well.
                      Jim, it certainly isn't leaded steel, it just turns like it. There is no trace of porosity in the welds and they can't be seen after turning except for disturbing the cut slightly.
                      YOD,
                      When I admitted to my wife that I might be making this thing a little.. um, stronger than is required she just laughed and got all sarcastic saying that I never did that before...
                      This is one of the idlers and I am using bearings that I happen to have since Tryp gave them to me when I picked up the shaper. They are well used and I rebuilt the bearing in this roller but that's another story.
                        I made an under cutter to mill a groove in starter cases so larger tie bolts and insulators could be used.Company I did the work for said the cases were 4130 aluminum killed silicon steel.It had nearly 5% silicon which is why one or two machined easy,but 5 or 600 cratered the carbide inserts unless they were Tin coated.I also noticed they took quite a while to rust.I had one dummy case that sat outside in the scrap pile and the cuts I made didn't sweat a pimple for a couple months.
                          4130 you say? That's a nice strong heat treatable alloy. I'll have to try hardening a piece and see what happens. Hardened idler rollers would be nice to have. Less damage and lower friction too.
                            Just an "aside" here....
                            When you get some spare time, maybe before lunch or during the Canadian High Tea/Donut break, you might want to consider knocking out one of these little beech bikes
                              I've been multitasking a lot in the last while. I'm working on several simultaneous projects as well as doing housework and preparing for the deck job. I've just about finished the picket twister and should be twisting metal later today.
                              The "tires" on that thing are just inner tubes, right?
