Grinder RPM's
  • Grinder RPM's
    A friend has made himself a small internal grinder to use on his home-built lathe. For grinding with, say a 1" dia wheel, what RPM's should it run at? I might find him a motor for his belt drive setup. Is there an ideal surface speed for this small grinding wheel?
    Thanks,
    Jack C.
    jc,
    "small" "home-built"; these are pieces of information that are tough to process.
    I have a Dumore tool-post grinder that can do internal work and I use it on a 12x36. The motor is a 1/4 horse with no-load spindle speed of 13,000rpm. You change pulleys to change rpm at the drive shaft, depending on the wheel/procedure.
    A 7/8" to 1" wheel would use a final drive spindle speed of ~21,000rpm, or ~ 5,000SFM.
    Wheels have a speed rating. If you spin a wheel not rated at that high rpm it will disintegrate in your face.
      Surface speed is pretty much always around 5000 fpm.... The wheel determines the RPM to get that.
      So 1" = 1/4 foot (3") circumference, 20,000 rpm gets approx 5000 fpm. Not all wheels of that size are necessarily rated for it, and balance is an issue......
      Too many "home-built's" in your post...... I'm already backing away...
