OT - follow up 4 Evan, et. al.
  • OT - follow up 4 Evan, et. al.
    RE: taskbar that wouldn't "autohide" after boot up.
    The culprit turned out to be Ad-Aware in auto scan mode. I had set it up to auto scan on boot up while I fixed breakfast. The taskbar gets activated when Ad-Aware starts up but does not get deactivated when Ad-Aware stops.
    Bob
    That is probably because Ad-aware has something to tell you about the results. Until you at least click and dismiss it it holds the task bar open.
      Actually, since I have always deleted everything it finds, I set it to delete and end. The only indicater I get is the "whoop" sound at the end.
        joahmon...I have been using SE free edition for sometime. After reading this thread I decided to buy it so I can set it to auto delete. I just ran it set it up and it still opens a window forcing me to select the files I want to delete. Could you help with what I am doing wrong?
        Thanks
        or Evan you may also know this as I know you are a wiz with software.
        Jim
        Life Is Grand
          Cybor,
          Click on the "gear" icon at the top of the window.
          Select "Start up".
          Choose an option from the "startup scan mode"
          Choose the options from the " startup action"
