Hi
Is there a specification for these kinds of Air powered pop rivet gun nozzle/tip. ie do they conform to "standard" sizes? Or are they "different" depending on manufacturer?
The unit I have came (2nd hand) without these tips. I would like to make some replacements and would like to be able to find out what thread size is used and the length of the tips. The length varies depending on the size (diameter) of rivet being used.
If there are no "standard" sizes then I will have to work form the example shown in the photo. This tip is from my normal hand operated poprivet gun. It does work in the airpowered tool but I did have to adjust the mechanism slightly to have it function properly (most of the time
There is no brand name on the unit - probably some Chinese import. There seem to be NO spare parts available from any of the local tool suppliers.
