Bandsaw Vise
  • Bandsaw Vise
    Has anyone improved the sliding part of the vise on the Jet, or HF horizontal/vertical 4x6/5x7 bandsaw?
    How do you make corner cuts on a square piece of flatbar?
    4 X 6 Band Saw Info
    You might want to take a look here:
    http://groups.yahoo.com/group/sawking/
    GHop Shop
    GHop
      I have a square-sided small Palmgren drill press vise that i use as an insert for small items. For larger stuff the existing vise works OK. I did add a jack screw to the movable jaw, too. You should find some good stuff (like the jackscrew idea) at www.minilathe.com
      Paul
      Paul Carpenter
      Mapleton, IL
